on 02-02-2023 09:36
Since Virgin Mobile switched to o2, our signal has deteriorated significantly, so WiFi callling is now needed. My phone is a Motorola Edge G20 lite, which has WiFi calling enabled, and that function works on the Three Sim (its dual sim). WiFi calling is not however showing up on the Virgin Sim. I spoke to one of your agents a couple of days ago, who confirmed it had not been enabled at your end, and said he had now set it up, but it still doesn't work. I've tried all the usaul things (restarted the router, powered the phone off completely for 10 minutes in case the update needed to be forced through, and so on, to no avail). It looks as though it has, for whatever reason, not been provisioned, as looking at the phone settings they are completely different for the Three sim compared to the Virgin one. Any ideas?
on 05-02-2023 11:02
on 05-02-2023 13:27
Appreciate that @mikefraser for the forum update.
May I ask what model of Motorola it is?
Has this issue always occurred or was it recently?
Did this issue occur on any other handset?
Kind regards,
Ilyas.
on 05-02-2023 13:47
on 05-02-2023 14:46
I don't see Virgin adding any more handsets with the pending move of everyone onto O2 this year
on 05-02-2023 15:59
on 05-02-2023 16:33
All the networks put that proviso up re firmware. However, O2 have not had special firmware on their phones since the start of 2018. ..5 years ago! It's all been bog standard manufacturers offering
on 05-02-2023 16:58
Hi Mikefreser, thanks for the message and sorry to hear that you are having issues with the WiFi calling.
Can you confirm if you have tried this indoors and outdoors and does this happen one one location or multiple?
Chris.
on 05-02-2023 17:38
I'll be surprised if WiFi Calling works outdoors
on 05-02-2023 17:55
Hi mikefraser, Is there a particular location you find that this never connects? or is it the same everywhere? ^Chris.
on 06-02-2023 12:21
