Daveyhorton
Why won't my phone work in rhodes?
I'm in rhodes and my phone won't work... I can't send texts or make calls
  • 2.04K
  • 225
  • 371
paulchambers061
Problem sorter
Re: Why won't my phone work in rhodes?
On your online account, is roaming switched on, and is international call barring switched off?
Did you get a welcome text on arrival?
If yes to all the above, have you tried manually connecting to all networks?
Note: Rhodes is near to Turkey, best not to try and attach to any Turkish networks, or you'll be charged. In fact, I'd suggest manually connecting to the cosmote provider.
Daveyhorton
Thanks I've sorted it I had to change the network mode to find the cosmote network...
  • 2.04K
  • 225
  • 371
paulchambers061
Problem sorter
Nice one...
