on 06-09-2022 15:05
I have recently switched mobile provider from sky to virgin mobile, I kept my old number from sky everything seemed to be fine but since the number swith I can no longer text sky mobile numbers, does anyone know why this is happening
[MOD EDIT: 13/09 ( RESOLVED) Issue Sky Mobile customers cannot receive Virgin Mobile text messages under investigation. Multiple threads merged into one]
on 08-09-2022 17:33
Hello richardsch,
Thanks for your post.
Sorry to hear you are having an issue with sending text messages to Sky Mobiles.
I'd like to take a look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
on 09-09-2022 09:34
There are now 36 replies on the same post on the Sky User Forum, obviously affecting a lot of people, many of whom are now slagging each supplier off for lack of progress.
09-09-2022 09:35 - edited 09-09-2022 09:39
https://community.virginmedia.com/t5/user/viewprofilepage/user-id/869341
Are you still getting this problem too?
on 09-09-2022 10:09
Thanks for coming back to us @Digger1950.
I would be happy to take a further look into this for you but would need to confirm a few details via private message, please look out for my message and we can get started.
Regards,
Steven_L
on 09-09-2022 10:42
For the last few days every text I send to my Daughter, her husband or my Grandson are not being received. They are all on Sky mobile. I can receive texts from them. Everyone else I send texts to get them fine. I don't get any error messages and the text shows as sent.
Anyone got any thoughts please ?
on 09-09-2022 11:00
Hello milair,
Sorry to hear of the text issues regarding sending messages to mobiles/SIM's using the Sky network. We understand the confusion this can cause and appreciate you raising this via the forums. Welcome to the community.
We have been made aware of an issue and the relevant team are liaising with Sky to investigate this further. I do need to get some more details from you to help wit the investigation and will send you a Private Message.
Rob
on 09-09-2022 12:39
Since the beginning of this week any texts that I send to sky mobile number are not being delivered. They say Sent my end but they are not delivered. What is going on?? I've called and been told "the service is fine its not virgins fault" that is all well and good but it does not help me. Is anyone else having the same problem?? It really needs looking into and sorting.
on 09-09-2022 12:41
Yep got the same issue, been like it for days. It is not good enough whoever fault it is.
on 09-09-2022 13:22
on 09-09-2022 13:32
Hi there @dispic1, welcome back to our forum and thanks for your post.
I'm sorry to see that the texts you are sending to a sky mobile are not going through. We can see that Sky are actively investigating this issue to see if this is an issue on their end.
We also have our support team investigating this on our end to ensure that this will be fixed asap. We will provide any updates to this as soon as they are available.
Nathan
