Chris_74
SMS problem
Hi just got a new iPhone with virgin and when I try and send a text message it is changing the number from 0 or +44 to +32 I have checked and changed my language and region any other suggestions would be gratefully received
enlli
  • 9.34K
  • 1.4K
  • 2.69K
Re: SMS problem
You can try this. You may not have to do the last bit
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Now make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region
Chris_74
Re: SMS problem
I have looked through these settings and changed them as you have suggested hopefully this cures the issue thanks
