chocolala
Roaming in Portugal
Not getting data roaming in Portugal -- ok in UK when good enough signal
All settings set on Samsung S5 correctly set and preferred provider is NOS.
Mostly able to use WiFi but nothing being received outside a wifi zone
Calls and text ok
Any help appreciated
  • 3.42K
  • 461
  • 903
Re: Roaming in Portugal
First thing to check is if data roaming is turned on in your phone settings. It's easy to miss.
Click to learn more about VIP
Use Kudos to say thanks
chocolala
Yep - just re-checked and it is on
International call barring is off  and
Premium call barring on
  • 2.31K
  • 50
  • 68
Moderator
Moderator
Hi there chocolala, welcome to our forums.
i'm sorry to hear that you are not able to use any data in Portugal.
i'm going to send you a private message so I can take a look at this further for you.
Nathan B
