Slammin
Roaming In Croatia
I'm travelling to Croatia on Thursday the 20th May. I would like to be able to use my phone there. As it's in the EU I guess that would be free with Virgin? I have the mobile app on my phone but can't seem to find any setting there for it, and I don't seem to have a login for the mobile website.
Can roaming be enabled any other way?
Thanks in advance
  • 5.22K
  • 718
  • 1.46K
teabag
Superstar
Re: Roaming In Croatia
Croatia will be covered with Roam Like Home  https://www.virginmedia.com/help/virgin-mobile-roaming-european-zone
To check Roaming is set-up ok, ring CS on 789 and ask them to check Roaming is switched ON and International Call Barring is turned OFF.
You can also do a automated check on roaming status, by ringing 789 > 4 > 1
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
Slammin
Thank you Teabag
