on 14-01-2022 17:42
Hi There,
I was using lyca and last month switched to virgin keeping my old number but unfortunately I won’t able to retain my number for iMessage or iCloud. On my device the mobile number says different.
I’ve tried to reach customer support couple of times but no luck. Can you please help me with this.
on 06-10-2022 18:26
It confirmed today.
I’ve tried every step. I can’t even change my number manually in settings.
on 06-10-2022 18:52
Thank you @AccioNox
If you search "my number" in your settings it should let you update this here.
Are you getting an error message when trying to do this?
If you then go to iMessage it will show what numbers / emails can receive imessages so you can un tick any incorrect ones.
Please pop back to us when you can.
Vikki - Forum Team
on 06-10-2022 19:29
I've tried re-entering my number again and again. It shows no error but just the temporary number.
on 06-10-2022 19:52
Okay thank you.
As the port only happened today, I would advise to wait 24hours, turn the phone off and on again and then try to change the number again.
Please pop back to us here to let us know if you are then still unable to change this.
I am sorry for any inconvenience that may be caused in the meantime.
Vikki - Forum Team
on 07-10-2022 15:15
Some of us on another forum have sussed this (It's not confined to Virgin) It seems when a number is overridden on a SIM card during a PAC iOS carries on using the original number. Sometimes this rights itself after a week or two.
Inserting a blank SIM which is then programmed with the new number and it works first time!
on 07-10-2022 15:27
Thanks for the useful information @enlli,
Are you able to post the link to the other forum for cross reference?
Regards,
on 07-10-2022 15:45
@Kain_W I will PM you a link to the thread . Last few posts are of interest
on 07-10-2022 15:51
So I have to wait two weeks?
on 07-10-2022 16:00
Many apologies for this,
Are you unable to send messages on the phone at all?
Let us know,
on 07-10-2022 16:02
H
I can, but any iMessage and FaceTime use my ID not my number.
I have tried resetting several times. Nothing is working.
