  • 11
DR1967
Over billing (more than double) !!!!!!
VM have taken £33 by direct debit.
My usual bill is £14 for unlimited calls/texts and 2gb of data.
I never come close to using 2gb of data but for some reason I have used 2.03gb which carries a cost of £19.
How can this be, surely this is incorrect?
I think VM have seen enough of my money both in TV/broadband and phone/mobile.
It seems loyalty stands for nothing and when you exceed your usage by .03gb you are charged the earth!!!!!!!
Time to move away from VM I think as they seem to be robbing me blind!!!
  • 25.05K
  • 1.04K
  • 3.98K
Re: Over billing (more than double) !!!!!!
are are charge per day when you run out of data so even if you use 1kb each day you eill be chargd i think its £2/day
