Robdf
Not registered on network
I am in Cyprus, first time abroad since joining Virgin, roaming enabled showing full signal, but not registered on network?
  • 8.82K
  • 294
  • 600
Re: Not registered on network
Hi Robdf,
Thanks for your post on the Community Forum and welcome. I'm sorry that you're having a problem with your data roaming service. If you are a new customer, please see the following details here: Before You Go.
Please verify that your data roaming setting on your mobile is enabled and that your APN settings are correct as noted on this post: Roaming - FAQs or you can find your handset on our following website to have the configuration settings for mobile internet sent to your phone: Online Send Phone Settings. If your handset isn’t on this list, you will need to manually reset the APN settings.
Also have a look at the following online Help & Support Page: Roaming Hub if you have access to WiFi.
If you are still having an issue with this, please send me a private message by clicking this link: PM me here and send the following details:
  • Full name on the account
  • Mobile number
Kind Regards,
Terri
Virgin Media Forum Team
Running out of data? Check out our top Mobile data tips
