No voice volume in Spain
Yermucker
3 different handsets, 3 different similar. Someone calls us we can't hear them, they can't hear us. Meaning you have to immediately call them back if it's someone you know, private number, forget about it. Now a quick search online shows this isn't an isolated thing, and vurhin are aware, bit zero fixes for it. Tried the different suggestions made, change to 3g etc but nothing helps. Rather than the usual line of its a foreign network answer, tell me why friends with us on O2, Vodafone and EE have no issues, but us, with 3 virgin contracts all have the same problem?
22 REPLIES 22
Dublin on Wednesday, exact same issue still. Calls coming in but no sound.
Adri_G
Hi Yermucker, thanks for posting on our help forum.
We're sorry to hear you're having issues with the sound on incoming calls while in Ireland, could you please try a manual network search on the device to see if there are any other networks to connect to while you're there? Let us know if this helps.
Also are you able to try the SIM in another handset to see if you still get the same issue there?
Please, let us know and we're happy to assist further.
Adri
Done all this before, new sim card, the lot. Its obviously not on the user end going by the flood of threads on here lately reporting the same thing.
Adri_G
Thanks for this reply, sorry to see you've tried all this and it was not of help. Have you also received a new SIM and still got the same issues?
Adri
Yep, new sim made no difference
Adri_G
We're sad to hear your SIM replacement did not help with this.
Have our team advised of any tickets raised to resolve this instead or other workarounds, on your previous communications?
Adri
Went over it all in April, nothing has changed since.
Adri_G
Thanks, Yermucker. Did we advise on any resolutions at all after the SIM replacement?
Adri
Think we had reached the end of the line as far as fixes
Hi there @Yermucker
Apologies for the service issues and the problems experienced getting this resolved. From further investigation we're aware of a problem outside the UK that we are currently investigating.
This may be the cause of the problems and we will update you as soon as we hear back in relation to this. So sorry for the inconvenience.
Thank you.
