on 10-08-2022 14:53
After being away in Spain I've not been able to connect to the Internet uess I use WiFi. Yes I've restarted and switched the phone off and on. I've gone an and off flight mode, I've changed the network setting so I have to select virgin and I've had it on automatic. Nothing works. What is the fix!?
on 10-08-2022 15:06
Hello Quinvarey,
Thanks for your first post and welcome to our Community.
Hope you had a good holiday.
Sorry to hear you are having an issue with the network connection.
Depending on what handset you have can you try this please.
To Switch back when in the UK:
For Android
Select Apps from Home screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Mode
Select Automatic and go back to Home Screen
For iOS:
Select Settings from the Home Screen
Select Phone Icon
Select SIM Applications
On newer iOS 14 - Settings -> Mobile Data -> SIM Applications
Select Roaming
Select Mode
Select Manual
Select International and you are done, go back Home screen to retry
To change back when returning to the UK:
Select Phone Icon
Select Roaming
Select Mode
Select Automatic mode - you are done, go back to Home screen
It is important that you set the SIM roaming app back to Automatic mode once in the UK or you will not be able to access service when you return.
Gareth_L
on 10-08-2022 15:17
Thanks for that but it still doesn't work.
I have an android BTW.
on 10-08-2022 15:25
Hi Quinavery,
I can look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
on 10-08-2022 16:36
Hello Quinvarey,
Thanks for those details.
We will need to send out a new Sim card for you.
We will do our best to deliver your order within 24hrs.
Once you receive it pop it in the handset and follow the instructions on screen.
Gareth_L
on 10-08-2022 16:39
oh, thats a shame. why do i need a new sim? will i loose any information if i change the sim?
on 10-08-2022 16:44
The information like calls and contacts are generally saved on the handset. The Sim is faulty and will need replacing. I tried resetting all the network settings from here and it didn't work.
Gareth_L
on 10-08-2022 16:50
Ok, thanks for explaining that.
on 10-08-2022 16:54
Can you please let me know if you have any issues with the new Sim Quinvarey.
Gareth_L
