on 11-11-2021 14:10
I have had 2 phone conversations and 3 txt conversations about the lack of internet whilst using data near Wolverhampton train station,
Post code wv1 1le to be specific, I have full bars of 5g but at the top of the screen it says no internet, the txt message service want me to txt them back from the area, I'm at work then so it's not easy
I understand that Vodafone own the towers, I'm being told that the service checker shows a good service, it's notany idei? Maybe someone could check or can I put a screenshot on here?
Answered! Go to Answer
on 19-01-2022 17:17
on 12-08-2021 16:37
Hi, is anyone else having issues with their mobile service in Wolverhampton city centre?
I have a strong 5g signal but cannot use data, make calls or send messages. This is only in the city centre, once I get to the edge of the centre everything works fine.
It’s been like this for at least a week.
on 13-08-2021 16:43
Hi @jdmoore31.
Thanks for your post 🙂
I'm so sorry to hear you're having issues with your service in the city centre, are there any known issues listed for this area here?
Let us know.
on 13-08-2021 16:50
Hi Sofia.
It’s not showing any issues.
Thanks Jonathan
on 14-08-2021 17:04
Having checked here jdmoore31 there does seem to be some fluctuation in the signal around the post code of your account which would explain the problems outlined in your original post.
Given that the services work fine elsewhere in other location it would appear to be a network issue and possible some mast issues in the City Centre.
Rob
on 15-08-2021 17:17
Hi Rob, thanks for the reply.
Does this mean someone knows about the problem and it will be fixed?
I haven’t been in the city centre the last few days, but a couple of friends have said they are having the same problem this weekend.
on 15-08-2021 17:56
I'm surprised nothing is showing in the status checker on Vodafone as you say others have had the problem, there must be more.
Of course Virgin can only report a suspected fault. It's down to Vodafone to fix.
on 16-08-2021 18:21
Do you have any further updates for us @jdmoore31?
Does the service status checker advise you of any faults in that particular area?
For SIM cards supported by EE - https://coverage.ee.co.uk/coverage/ee
For SIM cards supported by Vodafone - https://www.vodafone.co.uk/network/status-checker
Kindest regards,
David_Bn
on 16-08-2021 20:13
Still not working in the city centre earlier today. I was there around 12:30.
The Vodafone status checker isn’t showing any problems.
Thanks Jonathan.
on 18-08-2021 17:37
Hi Jonathon,
I've had a look at the Vodafone coverage checker and it looks like one of the masts in the city centre is down for maintenance. The following message is displayed:
We’re carrying out maintenance in this area at the moment to help improve our mobile network. We’re sorry if you’re experiencing any issues with your service at this time, we know how frustrating this can be. Maintenance is due to be finished by 20:00 18 Aug 2021 and we’ll update this page as soon as it has been done.
The good news is that it's due to be fixed later on tonight, so do let us know how things after from tomorrow if you're still having issues.
Beth
