on 03-02-2022 09:18
The last few days my mobile. signal keeps going to T Mobile. When I reset to Virgin it's ok for an hour or so then changes again to T Mobile even when the phone is in the same location like indoors. Have seen some comments that some are not getting any signal from Virgin is there a reason?
on 03-02-2022 09:35
Hello littleacorns
Sorry to hear this
We are in the process of updating our Mobile Network and using Vodafones network for 5g
Have you noticed this happening in various locations
I can take a look at this for you if you wish
If you don't mind, I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 03-02-2022 12:36
Hello littleacorns
Thanks for those details
I have had a look and can see the Mast near Gildea Park Station has had some planned work on it for the last 3 days
Which will be the reason your signal keeps dropping in and out
This will be finished as soon as possible
Gareth_L
on 03-02-2022 13:26
Thank you for your help explains loss of signal
