on 06-07-2022 10:59
For weeks now my mobile and everyone else within the households mobile cuts out mid call, I cant seem to get any help with this, is anyone else experiencing the same issue?
on 06-07-2022 11:12
Is this just one locality or wherever you go?
At home do your phones have WiFi Calling enabled?
on 06-07-2022 12:34
Its in the house it happen.
I don't believe I have WIFI calling enabled but will check
on 06-07-2022 14:20
Hi @woody2905
Thanks for posting on our community forum and a big warm welcome!
Sorry to hear about your issue regarding your mobile signal, does this only occur in your property? How do you get on when using WiFi calling if this isn't enabled already? If it is, can you disable it and see how you get on also?
on 06-07-2022 14:44
Thank you, I have enable WiFi calling so will see how that works,
on 06-07-2022 14:55
Hi @woody2905
Thank you for your reply
Please do keep us updated with how you get on with this and we'll look into this further if the issue still continues 🙂
