on 14-12-2020 11:02
I've recently joined Virgin Mobile partly so I can use the WiFi on the London Underground. However when I join the WiFi and it asks me to login I select Virgin Mobile and put in my login details but it won't log in and I get the error in the attached screenshot (I selected Virgin Mobile, not Broadband). I know my username and password are correct because they work when I log in to my account.
Please can someone advise what I need to do to get the London Underground WiFi to work?
on 21-02-2021 16:23
on 24-02-2021 11:23
Hi mahharg,
Thanks for your reply, have you been able to connect since your post? If not, then try removing both the connect app and the removing all previously saved London WIFI connections from your in the phone menu. The next time that you are in range of the London WIFI, create a new connection., not using the connect app.
You can also find more help here: https://my.virginmedia.com/wifi/faqs.html
Cheers,
Corey C
on 04-03-2021 15:06
on 24-04-2021 14:13
I've finally found the solution, at least for my Pixel 2 running the latest version of Android.
When selecting authentication method for the Virgin Media network, choose the SIM option.
The WiFi started working for me immediately. Hope that helps others!
on 24-04-2021 14:18
Thanks for the update inigojames and glad to hear this has now been resolved for you.
If you need us again in the future please don't hesitate to get in touch.
Rob
on 24-04-2021 15:49
on 24-04-2021 15:55
Thanks mahharg, we aren't aware of any changes. Details on the process can be found here and let us know how you get on next time you're on the Underground.
Rob
on 19-06-2021 16:56
I've got exactly the same issue on a Pixel 4 running Android 11. Used to connect without a problem pre-pandemic so something has obviously changed with the login since then. I will have to try the methods listed here to see if I'm able to connect.
on 20-06-2021 12:23
on 20-06-2021 12:42
Hi @petenice
Thank you for your post regarding your login not working for hotspots on the Underground.
Please try selecting SIM when selecting the authentication method for the Virgin Media network and let us know how you get on next time you're on the tube.
Many thanks,
Serena
