on 27-08-2022 12:47
Voicemail locked out, can't contact 789 as abroad, no idea what my pin is!
Answered! Go to Answer
on 27-08-2022 13:16
Hi there Deanna3,
Thanks for your post and a walm welcome to the community.
Many apologies for the problems faced, can I ask have you set a PIN up in the past for this?
Let us know,
on 27-08-2022 13:16
Hi there Deanna3,
Let us know,
on 27-08-2022 15:37
I think I may have had a pin before. Honestly can't remember though
on 27-08-2022 15:41
No problem, to investigate further I've dropped you a PM.
You'll find this message within the purple envelope icon,
Many thanks,
on 28-08-2022 15:08
I don't want any congratulatory emails or badges, I just want help with the question I posted earlier so I can unlock my voicemail in case I have an important message waiting!
on 28-08-2022 15:28
Hi Deanna3, thanks for the message.
I can see that the private message has been assigned to Kain and he will be in touch with you soon.
Chris.
on 28-08-2022 15:46
Thanks for your cooperation over PM Deanna3,
That should be sorted for you now!
If you do have any further issues then be sure to pop back up so we can advise further.
Take care,
