on 19-01-2022 14:24
I am having constant problems with making calls.I have a Samsung S10e and have restarted the phone twice checked the sim still have the same problem.
I have then tried on iPhone same problem.
I am nearly on the verge of changing to another provider.
Any suggestions
Answered! Go to Answer
on 19-01-2022 14:42
Thanks Arvind
Have you tried the Sim in another handset?
Also does this happen in just one particular area?
Gareth_L
on 19-01-2022 14:29
Hello Arvind
Sorry to hear this is happening
Can you please explain in a bit more detail as to what is happening when you call
Gareth_L
on 19-01-2022 14:35
When making any after dialing it just connect and i have try 2 or 3 times before call gets connected and rings
on 19-01-2022 14:42
Thanks Arvind
Gareth_L
on 19-01-2022 14:43
Meant to say when making call it jsu does not connect and no dial tone
on 19-01-2022 14:48
And is this in one particular area Arvind
Gareth_L
on 19-01-2022 15:16
Different areas
Downstairs
Upstairs and also outside
on 19-01-2022 15:28
What about away from your home Arvind
Gareth_L
on 19-01-2022 16:01
Yes outside also
Away from home
on 19-01-2022 16:09
Thanks for replying Arvind
I can look into this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
