  • 7
Mysterbee
Message 1 of 10
Data roaming in Crete not working
My moto g6 won't connect to data in Crete. I have updated the apn via text and checked it's the correct settings for my sim - purple sim so uses APN: internet.proximus.be  from what I can understand.  I've rebooted and left it for 24 hours. Any thing else I need to check or can do?
TIA
  • 1.6K
  • 68
  • 117
Forum Team (Retired) Joe_F
Message 2 of 10
Re: Data roaming in Crete not working
Hello Mysterbee
I am sorry to hear that, can you confirm if you activated your roaming before you left for your trip?
Thanks Joe_F
  • 7
Mysterbee
Message 3 of 10
Yes, roaming was on before we left.
  • 1.6K
  • 68
  • 117
Message 4 of 10
OK, Have you tried a manual network search on your device and tried to connect to the available networks that way?
Thanks Joe_F
  • 7
Mysterbee
Message 5 of 10
I'm on the phone network (GR Cosmote) so can make phone calls/text but can't use data services.
  • 1.6K
  • 68
  • 117
Message 6 of 10
OK and just to check, in your phone settings data roaming is switched on?
Thanks Joe_F
  • 7
Mysterbee
Message 7 of 10
... it won't manually connect to any other network.
  • 7
Mysterbee
Message 8 of 10
Hi, data roaming is on. Can I check the correct apn settings for the purple sim for my phone (moto g6) as I've seen several different  versions (none of which seem to work)!
  • 1.6K
  • 68
  • 117
Message 9 of 10
I am going to pop you a private message now 🙂
Thanks Joe_F
  • 7
Mysterbee
Message 10 of 10
Ok
