MorleySue
Settling in
Message 31 of 39
Re: Data roaming abroad not working
Hi.
I am in Rhodes at the moment and tried all the above suggestions but I still cannot connect to a network.
Can someone from VM help out? I can't call as I have no network.
  • 4.57K
  • 311
  • 277
Message 32 of 39
Hi MorleySue,
Sorry you're having some issues using the services abroad, I can appreciate you're keen to get this sorted.
Do you want to pop me a personal message so I can take a closer look?
Thanks.
Emma_C - Forum Team
  • 24
isisblues
Message 33 of 39
Hi Virgin Media
i have an iPad that has never worked in Europe. I have data roaming On and have reset Network Settings but still no joy. My iPhone works fine, iPod doesn't. -  help ???
  • 4.57K
  • 311
  • 277
Message 34 of 39
Oh no, this ins't good.
We'd need to take a quick look at the settings our end to see what's going on.
I'll pop you a quick message now asking for some further details.
Thanks 🙂
Emma_C - Forum Team
TheoT
Message 35 of 39
I am suffering from a similar problem now in Sweden. My Samsung Galaxy S8 functions correctly in the UK, but since arriving in Sweden yesterday my mobile roaming is not working. I have no access to calls, texts or mobile data, despite my phone showing full bars of signal. I have roaming switched on.
I have tried selecting network operators automatically, which doesn't do anything, and manually, which once resulted in a list of Swedish operators, but didn't allow me to join any of them. I have tried entering APN settings for Swedish operators, which hasn't worked, and have confirmed that my Virgin APN settings are correct (as expected, since my phone works in the UK).
I have tried restarting my phone multiple times, have removed and replaced the SIM card, and have checked for software updates. I never received a text welcoming me to another country, as has happened with other phones in the past, from Sweden or Belgium (on my stopover between flights).
Please let me know if there's anything else I can try.
Thanks!
[EDIT] I have tried swapping my SIM card with someone else's Swedish SIM for their S8, which worked correctly in my phone whereas mine didn't work in theirs. This implies it is a problem with my SIM card rather than a hardware issue.
  • 24
isisblues
Message 36 of 39
Last year my problem turned out to be that Roaming was not turned on in the account even though online it said it was. A kind person from Virgin turned it on and all was OK. That my fit in with that your issue is SIM related.
Best if luck !
  • 4.57K
  • 311
  • 277
Message 37 of 39
Hi TheoT,
I'm really sorry to hear you're having an issue using the services in Sweden, this ins't good.
Do you have our SIM tool kit app on your phone? It looks like a SIM card and settings cog?
If so then can you try the following:
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select Manual
Select International-you are done, go back to Home Screen
To Switch back when in the UK:
Select Apps from Home screen
Select Roaming
Select Select Mode
Select Automatic and go back to Home Screen
Let me know if that helps.
Emma_C - Forum Team
TheoT
Message 38 of 39
Hi Emma,
The matter actually seems to have resolved itself. After trying a bunch of things we had basically given up, then late in the afternoon all the messages suddenly came through. I imagine that it was a case of the roaming settings not catching up with the phone settings until then. Weird that it took so long. Thanks for telling me about that app, I can see the settings so I'll be able to try that if this happens again in the future.
Cheers,
Theo
  • 897
  • 46
  • 76
Message 39 of 39
Happy to hear that you're able to roam Theo.
Please let us know if you experience anymore issues.
Lisa
