  • 10
Thomo58
Data problems
I have just returned to virgin after 2years with three.
when on mobile data I can get on most apps the ones that I cannot get on are betting sites and FlashScores which is no good when I am out.
i have tried switching off and on and also switching settings off and on.
  • 2.09K
  • 230
  • 381
paulchambers061
Problem sorter
Re: Data problems
Most likely to be parental settings on your online account. Switch it off and restart your phone afterwards.
  • 10
Thomo58
Re: Data problems
It’s ok on WiFi
  • 77
  • 9
  • 12
Demogorgon
Up to speed
Re: Data problems
@paulchambers061 is probably right. You probably have one of those under 18 bars on. You need to either call them or go to your online account for mobile then under 'Manage Services' turn off parental block. Wait a couple minutes or 5, then reboot your phone.
