on 28-02-2022 10:08
I've recently switched from EE to Virgin mobile with my partner. We had absolutely no problems with making or receiving calls until we switched. I cannot call people, and people cannot get through to me either. If someone does get through to me for example my very important doctors appointment that I've had to reschedule this morning due to the poor signal, it cuts out constantly. My partner is having the same issues, however my stepson who has the oomph Sim does not have these issues. Could the issue be with the Sims? It is definitely nothing to do with our devices as the issue only started when we changed Sims. Thankyou in advance.
on 28-02-2022 10:24
Well, you will have switched from EE to the Vodafone network which Virgin use.
That said, I have noticed Virgin struggle in areas Vodafone users don't, so something is not quite right.
Is this in one location are all over?
Vodafone Coverage checker here
https://www.vodafone.co.uk/network/status-checker
on 28-02-2022 10:27
Hi, thanks for your reply. The problem seems to be all over at the moment.
on 28-02-2022 10:29
Can I also add that I currently have just one bar of signal and this has been this way since beginning to use this sim, my partner has the same.
on 28-02-2022 10:51
on 28-02-2022 11:03
Thankyou for your reply.
It says my area is running on 2G or at least that's what I can gather from the status checker I'm not 100% sure as I've never used it before, it is showing as red anyway, I'm assuming that means there are no issues in the area? We switched last week but we've both had issues with contacting people since then.
on 28-02-2022 11:22
@Tsgfuzzy wrote:Thankyou for your reply.
It should show the status bars for at least 4G 3G and 2G. If it is only 2G then that would be poor for a modern phone that really needs 3G or 4G to work properly
Can you give us a nearby full postcode, say a local shop or pub, and I'll check.
on 28-02-2022 15:13
Thanks for confirming that @Tsgfuzzy
It's very difficult for us the resolve as the mast's do not belong to us, they'll belong to Vodaphone. If this issue is affecting the area then I'm sure they'll also be looking to find and fix the issue for themselves. @enlli is an amazingly helpful VIP, if you can provide them the information they have requested we'll be able to investigate and advise further.
on 28-02-2022 15:16
Hi yes a nearby postcode would be WA11 0GR. Thankyou for your reply 😁
on 28-02-2022 15:44
Thank you. Both the Vodafone and OFCOM coverage checkers suggest you should have a good signal on all bands including 5G
However, further digging shows a mast out of action the other side of Liverpool Road and this may effect your signal.
I don't know what phones you have but you may well be able to activate WiFi Calling which should negate the problem at home.
