on 27-07-2021 21:01
Having problems accessing some sites for example William Hill,Skybet,Beerhawk,Drop Store and other sites similar to these.I phoned about problem and was told it's to do with children accessing sites when under 18.So was told parental control was now switched off but still no joy on sites mentioned above. TIA for any help.
on 29-07-2021 11:19
Okay, have you rebooted the device?
What did our team do for you when you called?
Zoie
on 29-07-2021 11:31
Yes device rebooted said they would take parental control off but might take up to 24hours.I have also taken parental controls off on my virgin mobile site
on 29-07-2021 11:33
Just a thought as I had a similar issue in the past with a different provider. It turned out not to be a network issue and the phone itself.
I had done the usual update which had installed some extra security. It maybe worth doing a internet search regards that for your device.
It gave me an option to confirm whether I wanted certain devices off there restricted list each time I went to those sites I was blocked from.
Hope you get sorted, good luck.
on 29-07-2021 11:34
Thanks for your reply,
Have you rebooted your phone since this ?
Zoie
on 29-07-2021 11:34
on 29-07-2021 11:35
Yes it's been rebooted
on 29-07-2021 11:42
As @Lightfoots given us some helpful advice on what happened with them.
Have you tried your sim in a different device?
Zoie
on 29-07-2021 11:45
I haven't but will give it a go when my wife returns and will let you know oh also I have an O2 SIM and it opens up sites I require no problem pity I don't get signal where I am at the moment
on 29-07-2021 12:15
Have tried in two other devices now and still no joy all that comes up when trying to get on sites is
This site cannot provide a secure connection
err_ssl_protocol_error
on 29-07-2021 12:19
Hi have now tried SIM in two other devices still no joy all it says when trying to get on these sites is
The site cannot provide a secure connection
