Steveabe
Message 1 of 5
Can't connect to a network when roaming.
I am having problems getting my Samsung S9 to connect to a network whilst roaming abroad.It will not connect automatic or manual, I get a message Your sim card does not allow connection to this service. I've have set roaming to on and international call bar is off. I even contacted virgin before I went away as the last time I was abroad I couldn't connect. They set it up for me, but, no I still can't connect. So here I am on holiday with no connection again. Wifi is ok. Can anyone help with this, please.
  • 743
  • 40
  • 152
Message 2 of 5
Re: Can't connect to a network when roaming.
Hi Steveabe,
Welcome to our forums and thank you for reaching out. I'm sorry that you've been having trouble using your mobile abroad.
I appreciate that you've checked the settings in your online account, but have you also ensured that roaming is switched on for your handset itself?
When you perform a manual network search, is there a list of networks to try or does it just come up with the error message right away?
Rachael
Steveabe
Message 3 of 5
Yes roaming is switched on on the handset.
When trying to connect in manual I get a list of service providers. I can't  connect to any. Just get the same message that the sim doesn't allow a connection to this service.
  • 3.96K
  • 277
  • 234
Message 4 of 5
Thanks.
Do you have the the SIM tool kit app on your handset?
It looks like a SIM card and a settings cog?
If you do can you try the following:
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select Manual
Select International-you are done, go back to Home Screen
To Switch back when in the UK:
Select Apps from Home screen
Select Roaming
Select Select Mode
Select Automatic and go back to Home Screen
Let me know how you get on.
Thanks.
Emma_C - Forum Team
Steveabe
Message 5 of 5
I used the sim tool kit and selected roaming - manual - international and now I'm connected. Thanks Emma C for the advice, 🙂👍
