on 30-01-2022 12:23
Since my package was refreshed on Friday (28 Jan), my phone keeps disconnecting from Virgin. I had exactly the same issue about 6 months ago when you updated my package. That took weeks to resolve and 2 new sims, but it has worked fine since then until Friday when you refreshed my allowance. On Friday it was dropping out all day, on Saturday it stayed connected all day, but today it is dropping out again. It isn't my phone, it is something to do with your re-fresh. Please can someone look into it.
I can't use the text service or ring because I can't guarantee having a mobile signal.
on 04-02-2022 12:05
Problems are still the same with the new sim. When I put it in it connected to network and stayed connected for a few minutes. Then set up notifications came through from Virgin and it lost connection. Currently I can't connect to network.
on 04-02-2022 15:35
Thanks for getting back to us @sueraf
Sorry to hear you are still unable to connect to the network, even with your new SIM card. That is not ideal. Can you confirm for me if your new SIM is now activated?
Best wishes,
Serena
on 04-02-2022 15:45
Yes. I activated it a few hours ago.
Susan
on 04-02-2022 15:51
Hi @sueraf,
Can you try turning Airplane Mode on, leaving it on for at least 30 seconds, and then turning it back off? As you've only very recently activated the SIM card this can help to push through the request fully with the network.
on 04-02-2022 15:58
Just done that - still no connection to network.
on 04-02-2022 16:30
Check out the purple envelope in the top right hand corner and I'll take a closer look into this for you @sueraf
Kindest regards,
David_Bn
