Vickster37
Can I use my data and calls in Turkey?
  • Can I use my data calls and txts in Turkey?
enlli
  • 7.41K
  • 1.17K
  • 2.09K
Re: Can I use my data and calls in Turkey?
Yes but you will be charged as Turkey is not part of Roam Like Home agreements
https://www.virginmedia.com/help/virgin-media-roaming-hub/Turkey#:~:text=All%20Virgin%20Mobile%20cus....
BenMcr
  • 21.59K
  • 2.35K
  • 4.36K
Turkey is not part of the EU, so roaming there is chargeable
teabag
  • 5.77K
  • 802
  • 1.65K
Hero
EDIT: Deleted as it was a third same answer 😂
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
