on 05-08-2021 17:56
I have a virgin mobile family plan with 4 phones. When any of us try to phone home to our virgin landline, the call frequently fails at the first attempt (probably more than 30% of attempts). The mobile doesn’t get a ring tone but the home phone rings. When answered, the mobile behaves as if connected (call timer starts counting up) but nothing is heard either end.
Answered! Go to Answer
on 24-03-2022 21:48
I have connection issues when calling two landline numbers in my contacts from my virgin mobile, the call doesn’t seem to connect but rings at the other end, sometimes it also can connect to another random number?
25-03-2022 09:40 - edited 25-03-2022 09:42
Thanks for clarifying vmlongtime, that is certainly strange.
I'll pop you over a private message now so I can take some more details and look into this with my colleague to see if we're spotting any patterns an find out what's causing this.
Please look out for my message over at the purple envelope
on 29-03-2022 17:56
on 29-03-2022 18:01
on 30-03-2022 12:16
Hey @SixString,
You sent over a private message to myself without being invited, this was breaking forum rules and you need to be invited into a private message.
Please can you try to do a manual network connection on the device that cannot call into your landline and see if this works to get the calls to your landline working.
Are there any other mobile numbers that cannot reach you on your landline number?
Regards,
Steven_L
on 30-03-2022 12:32
Hi Steven, You said....
See the post from David_bn below!
Hi @SixString, it appears that this has been marked as solved, and it appears that the OP was taken into a PM in the most recent public post.
I understand that you have been discussing your issue within a private message conversation with one of my colleagues.
If this is ongoing, please resume this conversation with my colleague
Kindest regards,
David_Bn
on 30-03-2022 12:53
Hi Steven,
OK happy to try anything to try and resolve this. 😁
You asked Please can you try to do a manual network connection on the device that cannot call into your landline and see if this works to get the calls to your landline working.
How does one go about this? The only manual connection I am aware of is when connecting to WiFi where the network name and password are entered manually.
The fault we are experiencing only happens with the three mobiles on our account, from any location, dialling in to the landline. At all other times the landline operates correctly. i.e. other peoples mobiles and landlines dial in OK.
on 30-03-2022 16:07
Thanks for the response there SixString,
Welcome back to the community!
It will depend on your device, if you check this link here you can find out how to manually select a network from your phone.
on 30-03-2022 16:27
I tried this. No difference. 4th call failed (landline wrang but no ring tone at mobile)
on 16-05-2022 08:29
This continues to be a massive irritation. It took 5 attempts last week to establish a call from one of our mobiles to home. Since Virgin seem to have given up on this problem again, I am cancelling our Virgin Mobiles today. I only switched to Virgin Mobile to get a better family deal because I was already a Virginmedia customer. Ironically I can now get a better deal switching back to O2.
