L7500030
Call Barring incomming calls Huawei P Smart
When attempting to apply call barring for all incoming calls (or any other call barring function) I repeatedly get the 'operation fail please try again' error message. I've tried every reported call barring code I can find (0000 1234 9999 etc...) nothing works.
Anyone come across a solution for this?
  • 4.66K
  • 314
  • 285
Re: Call Barring incomming calls Huawei P Smart
Hi L7500030,
Sorry you're having an issue barring all incoming calls on your handset, I can appreciate you're keen to do this.
Is this a setting specifically within the handset? Does it have any "do not disturb" options?
Is there a reason you want all incoming calls barred? If so we might be able to see if it's something we can do via the SIM card.
Let us know 🙂
Emma_C - Forum Team
L7500030
Thanks for the response Emma,
I'm working abroad for a few days which is fine but I'd rather not have people who call know that by getting a foreign ring tone so I need to bar incoming calls. Blocking all numbers will still mean a foreign ring tone before the 'leave a message' prompt right?
  • 4.66K
  • 314
  • 285
Ah, I see. No worries, that can be sorted.
If you'd still like this done then please pop me a personal message and I'll be happy to help.
Thanks.
Emma_C - Forum Team
