on 15-07-2021 21:10
Would be grateful for some advice
Previously on Three and I could forward my works phone to my personal phone and if I didn’t answer it then it would go to voicemail
Since moving to VM it forwards ok but then instead of going to answerphone if I don’t answer in time it rings busy and then disconnects
I’ve tried the support line and neither Apple or VM can fix it
is it something that isn’t possible or am I missing some setting somewhere
as an aside on if the support suggestions was to reset my network settings which I did. After that it should my recent call from my works mobile which is a UK number with a Belgium prefix 😬
on 15-07-2021 21:51
Not sure about the answerphone problem but regarding Belgian prefixes this is a common fault and can be cured as follows.
Go to: Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming" -> tap "Select Mode"
Tap manual -> then choose National.
Make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region.
on 15-07-2021 22:24
Many thanks for the reply
I’ve changed to national and the regional settings are OK
Still got the same problem but it’s not disconnecting after ringing. It changes to an out of order type of ring and then there is a message that says “this users phone is not available please try later “
It obviously recognises the phone as I can answer it but it just can’t take the next step of going to voicemail
Thanks again for taking the time to reply
on 17-07-2021 11:10
Hello austhorpe61,
Thanks for taking the time to raise you mobile query via the forums, we appreciate you raising this with us and welcome to the community.
We don't currently support call forwarding, as a virtual network using EE and have had no information to advise this will change on SIM cards using the Vodafone network either. This doesn't mean it isn't possible, it's just not a system change we can make or check here to resolve this.
Rob
on 24-07-2021 19:10
Many thanks for the quick reply
ive decided to cancel and go with EE as the other show stopper was no support for Apple Watch on cellular
Hey ho
on 25-07-2021 09:10
Hey @austhorpe61,
Thanks for the update, sorry to hear you decided to cancel but hope this works best for you.
Kind regards,
