  • 14
bubsterdoofus
4G Data Takes Minutes to Connect
When out and about I switch my data on now and again to check emails. Whether I'm in town or country, have a weak or strong 4G signal, it takes on average around 3 minutes to connect. Occasionally it will connect in about 2 seconds.
The connection settings are the ones Virgin automatically sent when I first registered the sim about a month ago. Texts and phone calls work fine. The sim is the newer purple one.
Is this the normal wait time?
  • 435
  • 19
  • 23
Re: 4G Data Takes Minutes to Connect
Hi bubsterdoofus
Thanks for the message.
Can you do a network search to see if anything changes?
Kind regards
Chris.
  • 20
miahj14
Hi Mate,
Have a look at my post, are you experiencing the same issue as me and alot of others, ?
