nhnh451
  • 5
Message 1 of 5
VM Hub 3.0 is working, but there are no green lights on the front.
I'm happy that its working, but it seems strange that there are no indicator lights (the white power light is on).
Does anyone have an explanation - and is it an actual issue (its a nuisance, but is it sign of something more serious?)
Tags (1)
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.9K
Message 2 of 5
Re: VM Hub 3.0 is working, but there are no green lights on the front.
Hello
The behavior of the lights on the Hub 3.0 are different compared to other routers. The lights on the Hub 3.0 will only be lit if there is an issue, otherwise, with the exception of the Base LED, the lights will be off.
Regards Mike
nhnh451
  • 5
Message 3 of 5
Thanks for the quick reply. I couldn't find a Hub 3.0 manual so was looking at a manual for the equivalent product (Connect Box from UPC in Switzerland) and there is a table that says the lights would be green for OK and red for a problem. I guess VM's variant works differently.
Do you know where I can find a user manual for the VM HUb 3.0?
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.9K
Message 4 of 5
Hello
Yeah thats the one I found but I know that VM do not have a manual for the hub 3 I am afraid, the VM will have different software than the UPC one, hence the differences.
This all I could get for you that tells you what the lights mean https://www.virginmedia.com/help/virgin-media-what-do-the-lights-on-your-hub-mean
RRegards Mike
nhnh451
  • 5
Message 5 of 5
Thanks Mike
