  • 7
richieb41
Message 1 of 5
Upsteam power levels & outside cable routing
My upstream power levels are 4.775dbmV which seems extremely low, but it's working ok, so i dont know.
Also, i was in the front garden yesterday, and found a big stone in the soil. I began to dig it out, but eventually found that my broadband cable actually goes though it. The stone is 12" x 6"x 3".
I wonder what i should do. Will Virgin come and remove the cable from it if i tell them about it ?
  • 14K
  • 1.48K
  • 3K
Message 2 of 5
Re: Upsteam power levels & outside cable routing
Its a known bug with the reading on the hub3. The actual value is 47.75dbmV, which is well in spec.
You will have fun telling offshore about that one. Might be better to wait for the Forum team. However expect a 100 quid charge for any work they do. It’s not a fault affecting your service.
Click to learn more about VIP
Use Kudos to say thanks
  • 3.62K
  • 201
  • 603
chenks
Community elder
Message 3 of 5
i'm curious to know who the cable managed to end up going through the stone?
they don't drill when laying the cable in your garden, they simply dig a trench and then cover up the cable.
did the stone grow around the around?
  • 7
richieb41
Message 4 of 5
Thanks for info on the Upsteam reading.
Regarding the stone, i have no idea how the cable became routed through the stone. Its a mystery !!
  • 4.59K
  • 309
  • 765
Roger_Gooner
Superstar
Message 5 of 5
A bit intrigued by a cable through a stone, can you post some photos?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
