  • 4.61K
  • 309
  • 770
Roger_Gooner
Superstar
Message 21 of 22
Re: Upgraded to VIVID 350. Homeplug/powerline speed not going above 190mbps
@danm77 wrote:
Well if you read this review of the devolo magic 2, which is the model above mine with theoretical speeds up to 2,400mbps, the reviewers achieved 456mbps when the adapters were placed in the same room as each other: https://www.techadvisor.co.uk/review/powerline-adapters/devolo-magic-2-wifi-powerline-mesh-wi-fi-rev...
The 456Mbps was a test of transfer rates, not a router's broadband to a second adapter. Note some of the article's other findings:
"Next, when tested in a more realistic setup with the second adapter in a room two floors away, speed predictably dropped – here to 119Mbps."
"Our third test was on the Wi-Fi performance in the second room (far from the original wireless router). In a non-Mesh trial, we achieved 104Mbps, which isn’t so far off the wired speed"
This showed that performance deteriorated markedly when not in the same room and that WiFi was slower than wired - both as expected.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 11
danm77
Message 22 of 22
Yes speeds drop when you move the WiFi adapter away from the main adapter that’s connected to the router - fully expect that to happen. Note that the review references a “real world” test and when both adapters were in the same room they achieved 456mbps. Obviously each home will be different depending on the wiring etc. However this surely proves that homeplugs can achieve speeds in excess of 190mbps.
Appreciate that the model reviewed is higher spec than mine (2,400mbps vs 1,200mbps).
