ParmaGomes
Message 1 of 5
Split a wall Ethernet point to give two wall Ethernet points
Complete nunce here. My house has pre-wired Ethernet to some rooms, but not my son’s room. In the living room is the house internet (Australian FTTN) and four Ethernet points, which each connect to four seperate points around the house. The wall in my son’s room is the same wall I already have a point on, just the opposite side. Currently I’m not using that point so one option would be to get an electrician to put in on the other side of the wall for him. In an ideal world I’d like to split the current connection and have two points, one on each side of the wall. Is this possible, from one Ethernet connection coming from the router? Cheers.
  • 251
  • 27
  • 67
paul0363
Superfast
Message 2 of 5
Re: Split a wall Ethernet point to give two wall Ethernet points
You can add another point but this will need you to either run another ethernet cable back to the router (assuming that there's a spare socket on the router) or adding an ethernet switch to add extra ports (and running ethernet cable from the switch's location).
  • 14.03K
  • 1.49K
  • 3.02K
Message 3 of 5
As this thread does not relate to equipment connected to the Virgin Media network in the UK, I have moved the thread to the General Discussion area.
Click to learn more about VIP
Use Kudos to say thanks
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 4 of 5
it doesn't even seem related to anything in the UK ! the mention of "australian FTTN" makes me wonder why the OP even thought of coming to this forum.
call me suspicious but i expect an update with a URL to a particular product at some point soon.
  • 6.15K
  • 471
  • 1.02K
Hero
Message 5 of 5
Maybe I should help the OP as I’m an Australian! Maybe not.
