  • 230
  • 24
MikeyMcG
Up to speed
Message 1 of 5
Not connecting to Virgin WiFi hotspots
I recently ran out of data on my mobile (Huawei P20 Pro). I remembered that Virgin has a wifi hotspot scheme where customers can connect to hotspots in their surrounding area. I think these are actually part of the domestic broadband setup? Anyway, I did a scan of my surrounding area and got notification of a Virgin hotspot nearby. I entered my account details to connect but I just got a "connecting" message and no connection was made. The same thing has happened now on several occasions. What am I doing wrong?
  • 11.85K
  • 1.56K
  • 5.26K
Message 2 of 5
Re: Not connecting to Virgin WiFi hotspots
In order to use the hotspots you need to have installed and set up the Virgin Media Connect app on the device you are trying to connect from.  Have you done this?
If so what does it say in the settings menu re you access status to VM hotspots?
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work.
Click to learn more about VIP
Use Kudos to say thanks
  • 230
  • 24
MikeyMcG
Up to speed
Message 3 of 5
Yeah, I have the app installed. When I try to connect to any hotspot I get a popup screen asking me to enter my VM username and password. Then nothing, I don't even get a message that it can't connect, it just sits as connecting until I cancel it. I can't even do a survey of local hotspots because I have no connection at the time. So I'm relying on my phone picking up a hotspot manually.
  • 433
  • 18
  • 49
SonarUK
Fibre optic
Message 4 of 5
you have to have an internet connection so the app can download the certificate/profile.
after that your phone should auto connect to VM hotspot.
I also think theres a limit on how many people can use the same hotspot - try walking around to the next free hotspot.
https://twitter.com/SeriousFamily
Vivid 350 | Hub 3 modem mode | Asus RT-AC86U (Stock-Firmware)
  • 136
  • 14
IKbrunel
Up to speed
Message 5 of 5
My previous post?  Gone, missing, deleted.. edited out?
