  • 13.12K
  • 1K
  • 3.04K
Message 11 of 12
Re: Need about 6m of hub coax with connectors
all the good answers or maybe not
coax of the right quality is available from places like amazon - read the descriptions - BUT changing the length of the coax will change the signal levels - that may or may not matter - search and you will find info
BUT its all at your risk - easy answer is give VM £99 and they will move the hub and the V6 and make sure all is ok
____________________
Tony
  • 1.06K
  • 49
  • 99
Moderator
Moderator
Message 12 of 12
Hi Celesta,
I can see from your most recent comment that you have found a work around for the trouble you are having by using an ethernet cable but you would like hub moved.
We can arrange this for you, however there is a charge of £99 for this to be done. If you would like to get this arranged, please let us know and we will be more than happy to help.
Lindsey_C
