So I have had a strange recurring issue for some time now.
My Hub is in modem Mode. Orbi is my router and mesh, and I have a lightwaverf link. It works for weeks and then some strange behaviour occurs: the hub reboots, the logs on the router record a DNS attack and the link disconnects.
as per lightwave I have enabled port forwarding, as we assumed that the firewall on the orbi eventually blocks traffic.
we have also swapped the hardware, so it’s not the link, swapped the orbi, which is also therefore likely not the issue.
so could it be that the hub blocks certain ports, even in modem mode? If so, can I enable port forwarding on it?
