If your installing kit like IP-CCTV and alarms you need to think about having a more resilient setup for your home network,
Having router separate means its also safe from rebooting at a critical time due to a firmware up or maintenance by ISP.
I also run cameras from separate POE Ethernet Switch so that if router goes down, cameras still have an online port to connect to.
