Howardeadie1
Hub4
Anyone know why the my shiny New Hub 4 keeps buffering the tv never had this problem on Hub 3
paultechy
  • 19.76K
  • 1.74K
  • 4.1K
Re: Hub4
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
Howardeadie1
Re: Hub4
Thanks will give it a go.
