  • 9
Mikeyclarke1988
Message 1 of 16
Hub 3.0 swap
Hi, long story short, I was with virgin last year, and all was fine. Left for sky ( stupid I know) and came back after a few months. Now I'm having issues with the broadband dropping out several times a day. The only thing that has changed is the hub 3.0 box itself. OK so my question, I still have my old 3.0 box from last year. Can I unplug my current one which I assume is faulty, and plug in my old 3.0. Would this work? I have spoken to virgin tech and I have had engineers out to do repulls etc, but the problem persists. As I say the only thing which has changed since last year and no issues... Is the box. Thanks in advance
  • 12.69K
  • 970
  • 2.88K
Message 2 of 16
Re: Hub 3.0 swap
they may reactivate it - you would have to ring and ask - BUT it might not be that - all that has changed is the hub3 but thats just your side - many things can have changed on the network so start with some info
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
____________________
Tony
  • 9
Mikeyclarke1988
Message 3 of 16
Re: Hub 3.0 swap
  • 9
Mikeyclarke1988
Message 4 of 16
Re: Hub 3.0 swap
I can't see what your referring to?
  • 12.69K
  • 970
  • 2.88K
Message 5 of 16
Re: Hub 3.0 swap
you have not followed what i said - the key thing is - Do not sign in
Tony
  • 9
Mikeyclarke1988
Message 6 of 16
Re: Hub 3.0 swap
  • 25.23K
  • 1.05K
  • 4.03K
Message 7 of 16
Re: Hub 3.0 swap
WOW them power levels and SNR's are all over the place. That needs looking at.
  • 9
Mikeyclarke1988
Message 8 of 16
Re: Hub 3.0 swap
Looking at by a virgin engineer I'm assuming? If I phone them up what do I tell them
  • 12.69K
  • 970
  • 2.88K
Message 9 of 16
Re: Hub 3.0 swap
yes that helps
you only show 16 downstream channels there are usually more but of the ones you show the some of the levels are out of spec -6 is the minimum plus the snr on the channels you show are all low - cannot remember the minimum - i think its around 34/35
the pre rs errors are awful - they may be historical so reboot the hub and that should zero them - post them again in a few hours if they rise
the post rs errors are good at zero so the hub is doing its job there
theres a bug in the upstream level readings/reporting - move the decimal point one place to the right so the level is 40 not 4.0 - yours are fine - your upstream is 16qam - that could be correct or it could be a fault - VM would have to confirm that
all in all not good - a look at the complete downstream channels and maybe a tech to sort the problems
at this point swapping the hub will do nothing imo
Tony
  • 25.23K
  • 1.05K
  • 4.03K
Message 10 of 16
Re: Hub 3.0 swap
34 for the SNR is good. It can be seen lower down to 30 without problems in some frequencies if the power level is high enough. But with the range from 0.2 to -7.2 that is all over the place and not something you'd expect to see.
check the connection is secure first than see if you can get an engineer out to adjust at the cab
