NidianSmith
How to control christmas lights using my iPhone X?
I want greater control of my christmas tree lights, How can i do it? Which christmas lights need to buy?
  • 16.26K
  • 1.36K
  • 3.31K
Re: How to control christmas lights using my iPhone X?
you could look at something like -> https://www.amazon.co.uk/Insight-Switch-Control-Lights-Appliances/dp/B00H51XYLY or cheaper version -> https://www.amazon.co.uk/Oittm-Socket-Google-Function-Socket-White/dp/B076Z9CLPS/ref=pd_lpo_vtph_147...
