  • 6
Lyntee39
Help
Can anyone help with this, it appears everytime we use the YouTube app
  • 18.86K
  • 1.65K
  • 4.12K
Re: Help
in the settings -> general should be option stats for nerds need to turn that off.
  • 6
Lyntee39
Re: Help
Thanks but that never worked
  • 6
Lyntee39
Re: Help
Thank you I got it eventually I was in the wrong bit, thanks for helping
