pm_123456
Message 1 of 5
Connection Issues - low power on downstream bonded channels
I'm having loads of issues with both my phone and my work laptop dropping off the network despite network showing no issues.  Video conferencing calls, even just on voice only are now practically impossible.  I've done a few basic speed and ping tests and there seems to be no issues but my downstream bonded channels look low on power from what I can make out from other posts?
13227500004.840256 qam24
2138750000640256 qam1
31467500005.940256 qam2
41547500005.640256 qam3
51627500005.540256 qam4
61707500005.340256 qam5
71787500005.140256 qam6
81867500005.340256 qam7
91947500005.140256 qam8
10202750000540256 qam9
11210750000540256 qam10
12218750000540256 qam11
132267500004.940256 qam12
142347500004.840256 qam13
152427500004.540256 qam14
162507500004.440256 qam15
172587500004.540256 qam16
182667500004.540256 qam17
192747500004.540256 qam18
202827500004.440256 qam19
21290750000440256 qam20
22298750000440256 qam21
233067500004.140256 qam22
243147500004.540256 qam23
DJ_Shadow1966
  • 7.12K
  • 1.36K
  • 2.02K
Message 2 of 5
Re: Connection Issues - low power on downstream bonded channels
Hello
Look at what you have posted these are well within the specs they should be in the region of -6 to +10 dBmv, can you post as well as this one the reset of your downstream, your upstream and also the network logs.
Regards Mike
pm_123456
Message 3 of 5
Ah sorry - I'd missed the minus bit! Thought lower than 6 is an issue, here are the rest of the sections
1Locked40.926281741255
2Locked40.9401722441
3Locked40.3441339460
4Locked40.9446810538
5Locked40.9488589563
6Locked40.3525133778
7Locked40.3562087711
8Locked40.3612029550
9Locked40.9595764698
10Locked40.9678797814
11Locked40.3779933756
12Locked40.9848554847
13Locked40.39563971046
14Locked40.91045339896
15Locked40.91115867957
16Locked40.311498891000
17Locked40.912435888906
18Locked40.313254108911
19Locked40.914331991073
20Locked40.316274988912
21Locked40.318469998936
22Locked40.319961591622
23Locked40.921343781635
24Locked40.323187161519
1536999384.4512064 qam4
2462000274.325512064 qam1
3393999334.275512064 qam2
4326001154.25512064 qam
3ATDMA0000
4ATDMA0000
pm_123456
Message 4 of 5
Can't get a copy of the log in here for some reason sorry
DJ_Shadow1966
  • 7.12K
  • 1.36K
  • 2.02K
Message 5 of 5
Hello
There seems to be a little noise on your down stream, so in these cases can normally be resolved by going around and making sure that all coaxial connections to all VM equipment are finger tight, best way to do this is too undo the connector and then re-tighten, once that is done power of the hub for 30 secs and then back on, and I am hoping that should resolve the problem, if not then a engineer will be needed.
Regards Mike
