on 03-08-2022 00:29
I'm considering a stream but I'm wondering if it works if I chose to use OpenDNS on my router? I've checked the FAQs and it says you can use the hub in modem mode but wondering if it requires VMs DNS, if so, is it just for the setup as with the regular TV box or does it require it beyond setup?
on 05-08-2022 15:38
Hey @handsomeinked,
I'm currently looking into this but I'm pretty sure that you would need to be connected to the VM network DNS to be able to use the stream services.
I will get back to you as soon as I have a response or an update.
Regards,
Steven_L
