on 29-11-2022 01:12
Hey.
How does the watchlist work. Iv pressed the red button in some programmes but there is no rail containing these programmes. Am I missing something?
thanks
on 29-11-2022 13:45
Have you set up profiles on the Stream box?
If so any watchlists that you set up are profile specific, so if you set up a watchlist on say the main profile and then switch to a different profile, for example one you've named profile2, the watchlist won't show on the Home screen rail of profile2.
I'm not sure if the Stream works in the same way as the 360 for watchlists, but on the 360 the quickest method is to use the voice control and say "Add to watchlist"
On the 360 if you press the contextual button (just above the channel up button) and then select Info you can then add the program to the watchlist-
Also on the 360 you can also use the voice control and say "Info" and then add the program to the watchlist.on the screen that opens
on 01-12-2022 16:59
Hi @Jsquires1990,
Welcome back to our community forums and thank you for your query regarding using the watch list feature.
Was the great advice given by @newapollo useful? You may also find the following link useful https://www.virginmedia.com/virgin-tv-edit/tips-and-tricks/virgin-tv-go-app-simple-tricks-to-improve...
Please let us know if you need any further help
