Stream Box problems
bigfreddeh
A couple of days ago I read a comment about ‘Soft Resetting’ my stream box. Well, now, it’s every single day. I’m unplugging the power lead, holding the power button in, doing a soft reset and it works again. But surely I shouldn’t be doing this every day? Do I have a faulty box? Do I have another problem? Has anyone experienced this?
thanks.
1 REPLY 1
Kain_W
Hi bigfreddeh,
Thanks for your post and welcome back to the community.
Sorry to hear about the issues you're facing with the Stream box, from checking our forums however I can see that you have another thread regarding this.
To avoid confusion we'll allow responses to occur from there.
Regards,
Kain
