on 05-05-2022 12:30
Anyone know if you can connect harmony hub universal remote to the Virgin Stream Box? Have tried the Ziggo DVR but it doesn’t work.
on 29-12-2022 15:36
I'd also like to know if anyone progressed further on this please. Just got my Stream box and also keen to integrate it into my Harmony hub and link up with HomeAssistant.
on 29-12-2022 16:45
on 30-12-2022 20:24
Just updating this to say it works great!
Using Emulated Roku in Homeassistant to map all the buttons on the Harmony remote to fire off the commands on the Stream Box.
on 21-01-2023 00:43
I have managed to add it by manually teaching the on/off command as this does have an IR element for your other equipment however no other command works. This does however allow you to (if you have your harmony paired with Alexa etc) to use voice commands to turn on all your devices including the Stream box however changing channels etc does not work.
on 25-03-2023 12:39
I've just tried that, but when asked to point the remote at the hub so it can learn the command, no IR is emitted, given the Virgin Media remote doesn't have IR capability. Am I missing something?
02-09-2023 08:07 - edited 02-09-2023 08:10
Did this issue ever get resolved? The Virgin Media Stream box is recognised in Harmony as Arris VIP5002W. However, this does not work. Neither do the Ziggo options mentioned above. We only use the Stream box for the Sky Sports and BT Sports live TV and hence are thinking of getting either Roku or Chromecast with Google TV instead. Most likely will go fo the Roku as it supports Plex and Britbox as channels (apps) whilst Chromecast doesn't unless you cast. These things should just all work together without all this nonsense. 😕
on 06-09-2023 19:50
When trying to set up Ziggo Next Mini it fails with a message saying the Ziggo uses RF and the Harmony uses IR.
Is it not possible to use the Virgin Media Streamer with a Harmony Hub/Remote?
on 02-10-2023 20:58
Hi. I'm new to HomeAssistant. How do you set it up. Need a step by step guide please.
