Remote and stream box won’t connect
Adam98
My remote and stream box won’t connect will hold the tv button and 0 but comes up pairing failed on the tv
1 REPLY 1
Hi Adam98
Please try the following.
Unpair the remote in case it's already paired with a different TV:
•    On the remote control, press and hold the 'TV' button and the 'Rewind' button together for 10 seconds.
•    The remote control should now have unpaired from the box.
Pairing:
•    Put the box into 'Pairing Mode' by pressing the Standby/On button on the front of the box for 10 seconds.
•    On the remote control, press and hold the 'TV' button and the '0' button together for 10 seconds.
•    A message should appear on the screen confirming that pairing was successful.
Dave
The do's and don'ts.
