  • 10
stally
Message 11 of 20
Re: wireless speed full 200mbps Ethernet unable to go past 110
  • 86
  • 6
  • 14
goslow
Up to speed
Message 12 of 20
stally
Takes a while for images to be approved so can't see those posted as yet .....
You mention in #3 above that you had this issue with the SH2 as well. That kind of suggests possibly more something to do with the ethernet/LAN side of things than a VM problem.
As per -tony-'s suggestion at #8 above, what do the link light colours on the network connections for the PCs and the back of the SH3 show the negotiated speed is when you are only getting 100 Mb/s? And also similarly following same suggestion, do you want to post your SH3 stat's and logs if only to eliminate them from the process?
Are the two PCs the same make/model/device?
Are you able to test with a different device (gigabit laptop connection maybe from friend/family/neighbour)?
Where are you getting the latest drivers from for the ethernet connections? For a particular make/model of device, I can think of lots of occasions when I have had to use a very specific driver i.e. only one single driver variant would work at the right speed, sometimes an older driver version for a particular device.
I have also found that with some individual devices on Win 10 that they might only work with either a) very specific drivers direct from the manufacturer or b) only work with the latest MS drivers from the Windows Catalog for Win 10.
  • 7.97K
  • 823
  • 1.24K
Message 13 of 20
Some recent reasons for low speed connections....
Dell speed problem
https://community.virginmedia.com/t5/Speed/Download-speeds/td-p/3894056
Chrome speed problem
https://community.virginmedia.com/t5/Speed/Etherent-speed-slow/m-p/3912102#M202773
Turbo LAN App problem
https://community.virginmedia.com/t5/Speed/Slow-speed/td-p/3896582
Windows re-install
https://community.virginmedia.com/t5/Networking-and-WiFi/Achieve-Full-Speed-In-Safe-Mode-Only/td-p/3...
Old Network Card driver
https://community.virginmedia.com/t5/Speed/Vivid-350-just-installed-but-relatively-low-speed-connect...
  • 10
stally
Message 14 of 20
Yea i dont think its a router problem since we replaced it
lights on the back of the hub are green the pc is orange and green
both pc's are totally different in every way
unfortunately i have no access to another laptop hence the vm engineer going to come round with his
drivers i started with Microsoft auto downloading then changed to latest direct from intel i will go and try different versions of drivers.
thanks
  • 10
stally
Message 15 of 20
dell speed: no such program plus did a safe mode to eliminate programs interfering
chrome speed: in safe mode used a clean install of opera
turbo lan: is another program problem safe mode eliminated that problem
windows re install : i mean nobody wants to do that seems unlikely due to 2 pc's having same problem.
old network card driver: in the process of trying different drivers but unlikely the problem as again 2 pc's
thanks for your help
  • 86
  • 6
  • 14
goslow
Up to speed
Message 16 of 20
I believe a green link light on the SH3 is gigabit link speed? Anyone else, is that right?
What sort of age are the PCs and what operating system(s) are you running?
The auto-download for Windows doesn't always get the truly latest MS driver. Worth double-checking with the MS catalog.
However, with an Intel device I would start with Intel website direct for the latest driver.
With an Intel device make sure you get the driver only and don't get any of the ProSet(?) management garbage from Intel installed along with it (I think you can often pick driver-only as an option during the setup or alternatively unzip the installation package and use device manager to install the driver only 'inf ' files). ProSet has often been a nightmare in the past for me for screwing up network connections.
(You can see if the ProSet software was installed in your earlier attempts by looking in 'Programs and Features' in 'Control Panel').
  • 12.79K
  • 974
  • 2.91K
Message 17 of 20
going to ignore al the reasons above - with respect i think they are not relevant - key is 200 via wifi - slow lan connection - just to put my bit in all levels are good - thats was obvious really as the wifi speed confirms that
so what are you testing via wifi - agood phone or tablet or the pc via wifi - thats important in my mind as is the fact you can get 200 via wifi
there is nothing wrong with the input so a couple of suggestions
check settings on pc for lan card - it may be gigabit but devices could have it configured as 10/100
try a different lan cable be sure its cat5e or better - you say the one you are using is from VM - there are posts on here that say VM are still issuing cat5 cables with some gear
if a new lan cable does not cure the problem then do a full reset on the hub3 - a good 30sec of the reset button and try wired speeds again
____________________
Tony
  • 10
stally
Message 18 of 20
All points to the lan card so im going to try several drivers as it seems to be the only logical problem here thanks for everyone's help in the situation i will post a reply if i find the problem or not.
  • 86
  • 6
  • 14
goslow
Up to speed
Message 19 of 20
As someone mentioned at the start, there have been lots of similar threads to this one. Would be interested to hear the outcome, successful or not.
Hope you can get it sorted.
  • 10
stally
Message 20 of 20
Just a quick update, So after tirelessly going thru various drivers from Intel site and the motherboard site I'm still at the same situation anymore ideas are welcome.
