on 31-10-2021 12:34
Experiencing intermittent drops and upstream packet loss on a daily basis. Example below:
1 | 53700000 | 37 | 5120 | 32 qam | 2 |
2 | 39400000 | 38.5 | 5120 | 32 qam | 4 |
3 | 46200000 | 38.5 | 5120 | 32 qam | 3 |
4 | 60300000 | 37 | 5120 | 32 qam | 1 |
1 | ATDMA | 0 | 0 | 54 | 0 |
2 | ATDMA | 0 | 0 | 61 | 0 |
3 | ATDMA | 0 | 0 | 35 | 0 |
4 | ATDMA | 0 | 0 | 35 | 0 |
Tested from wired clients, so not sure if this is a line or a router issue?
on 04-12-2021 12:28
@boltedenergy wrote:@carl_pearce any idea what could be causing it?
A damaged line.
SNR in the local area.
VM need to investigate further
on 06-12-2021 13:40
Good Afternoon @boltedenergy, I'd like to see if we can have an engineer booked to take another look into this for you, check out the purple envelope in the top right hand corner for a private message from me
Kindest regards,
David_Bn
10-12-2021 12:48 - edited 10-12-2021 12:49
21 | Locked | 34.345688 | 69486 | 0 |
32 | Locked | 34.345688 | 51600 | 0 |
33 | Locked | 35.595078 | 43090 | 0 |
34 | Locked | 35.595078 | 78940 | 0 |
35 | Locked | 35.595078 | 32705 | 0 |
36 | Locked | 35.595078 | 34478 | 0 |
6 | Locked | 33.834164 | 87985 | 0 |
7 | Locked | 33.956509 | 81920 | 0 |
8 | Locked | 33.956509 | 76329 | 0 |
9 | Locked | 34.345688 | 62310 | 0 |
10 | Locked | 34.345688 | 78057 | 0 |
11 | Locked | 34.345688 | 73852 | 0 |
12 | Locked | 34.483570 | 60991 | 0 |
13 | Locked | 34.345688 | 70456 | 0 |
14 | Locked | 34.345688 | 70000 | 0 |
15 | Locked | 34.345688 | 64371 | 0 |
16 | Locked | 34.483570 | 72784 | 0 |
17 | Locked | 34.345688 | 76805 | 0 |
18 | Locked | 34.345688 | 72529 | 0 |
19 | Locked | 34.345688 | 65968 | 0 |
20 | Locked | 34.483570 | 72614 | 0 |
22 | Locked | 33.956509 | 92733 | 0 |
23 | Locked | 33.834164 | 76681 | 0 |
24 | Locked | 33.956509 | 70140 | 0 |
25 | Locked | 33.834164 | 69833 | 0 |
26 | Locked | 33.956509 | 64990 | 0 |
27 | Locked | 34.345688 | 55600 | 0 |
28 | Locked | 34.345688 | 58946 | 0 |
29 | Locked | 34.345688 | 58637 | 0 |
30 | Locked | 34.345688 | 52213 | 0 |
31 | Locked | 34.483570 | 50203 | 0 |
this doesn't look good? Pre RS Errors
on 12-12-2021 12:59
Thank you for the update @boltedenergy.
How was the engineer's appointment? Does the issue persist?
on 15-12-2021 11:15
The latency and packet loss have stabilized for now so looking good.
on 17-12-2021 11:31
Hi @blotedenergy. Thank you for getting back to us - really pleased to hear this!
Please do let us know if you have any further issues.
All the best.
on 08-01-2022 16:45
problem is back:
on 10-01-2022 17:54
Hi there boltedenergy,
Thanks for responding and welcome back to the community.
So sorry to see that the issue has crept up again 😞
From looking at your base settings/tests I can't see anything apparent that would be causing the packet loss.
Samknows has picked up a couple instances this week, both being of seperate days with a max total of 7 minutes. Can I ask whether that is happening more often than that?
on 12-01-2022 09:07
This looks abysmal to me. is the SH4 just broken or what?
13-01-2022 10:02 - edited 13-01-2022 10:14
