  • 64
Exoticcshot
when my upload going to 64qam
hi just want to ask when my upload going to be put on 64qam because I am still on 16qam did have a upgrade last year in my area aswel I though virgin would of done it at the same time so just want to no when its going to get upgraded my upload?
hope to hear from you soon
exoticcshot
  • 13.54K
  • 1.42K
  • 2.84K
Re: when my upload going to 64qam
Virgin cant "put" you on 64 QAM.
Under optimum conditions your hub will use 64 QAM for upstream, but if their are noise issues on your network segment the service automatically drops to 16 QAM.
The question is are you getting the correct upload speeds? If you are then it does not matter what modulation is used.
su1718.jpgCable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
  • 15.4K
  • 1.6K
  • 3.42K
Do you have a problem with your connection?
